Results 1 to 12 of 12
Thread: Looking for Castle Hydra
    Feb 2024
    OK
    12
    Default Looking for Castle Hydra
    Just as the title says, I'm looking for a 240A+ CC Hydra. A member on the here suggested a Hydra. "Castle Hydra XLX2. All day, everyday, and twice on Sunday". Thought i might test the waters and see what's out there. Thanks!
    4,131
    Sep 2007
    2,783
    Probably help to be more specific as all of Castle Marine ESC's have been called Hydra's.
    Hydra 60
    Hydra 120
    Hydra 180
    Hydra 240
    Hydra 240HV
    Hydra ICE 240
    Hydra ICE 200HV
    Hydra X8S
    Hydra XLX
    Hydra XLX2
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    Feb 2024
    OK
    12
    Yeah good call. That might help a little bit!
    I have a 55" dumas with a 5692 730kv motor. I'm honestly just planning on using this at a nearby pond and lake we go to in the summer. After a bit of research I decided that 8s was probably my best bet even if I wasn't going for speed with this hull. I think anything over 240A would be sufficient. I' try to update the post. Thanks for pointing that out. Danny
    Sep 2007
    2,783
    Danny,
    The best ESC with the most overhead will be the newer XLX2 hydra. OSE sells this as does Stump Fabrication.
    https://stumpfabrication.com/collect...e-esc-8s-33-6v
    https://www.offshoreelectrics.com/pr...as-010-0173-00
    Tyler Garrard
    9,402
    Since you are here Tyler, what would be the largest 8S powered mono I could run with a XL8S Hydra with say a 1000kv 'ish 40mm motor? Unless it could handle a 56mm x 84mm 1000kv'ish motor. For sport fun runs
    Sep 2007
    2,783
    Ray, you can likely drive a pretty big S mono in the 40-50" range. Running a larger higher pole count motor like the TP56mm would be more efficient than running a 40mm at high RPM's.
    A TP5670 on 8S2P would be no issue for the XLX2.
    I have logged 315A average over for a heat race before where I threw on a big wheel and the ESC had no issues. The batteries were a little toasty, but these ESC's can handle it.
    Tyler Garrard
    9,402
    NIce, thank you. I guess the smaller Castle might not be as robust to run say a SSS 5684 1000kv.? It's a 6 pole and I used to run a 1200kv version in a 40" mono on 6S with a SF240 and a Prather 240 prop.
    Sep 2007
    2,783
    The smaller X8S is a great ESC, but cannot run much above 300A unlike the large XLX2 which will allow short bursts over 500A. On big motor mono's you can see pretty high spikes so the extra headroom is nice to have. In a big hull you have plenty of room for the XLX2. You can try running the smaller one, it will likely current clip.
    The Q setup is fine for the XLX2.
    Tyler Garrard
    9,402
    Thank you. Sound advice. I also have a converted XL2 that might be better for the big boat?
    Really appreciate this.
    Sep 2007
    2,783
    The converted ones work almost as good. Should not be an issue.
    Tyler Garrard
    Dec 2014
    Ga
    544
    At the Valdosta record trials. I ran for the P SAW record (didn't get it) and on one pass my XLX2 recorded 674 amps!!!
    They are strong ESCs
    AmpDaddy
    don huff
Tags for this Thread
