Results 1 to 7 of 7
Thread: lipo battery wires
    Mar 2023
    TN
    172
    Default lipo battery wires
    How do I replace the wires on a lipo battery the gun I have isn't melting the solder?
    4,119
    You need a soldering iron with more heat capacity, possibly even a broader tip too. Something that can reach 750C. I use a Hakko FX888 adjustable solder station
    Mar 2023
    TN
    172
    thanks I was told I need flux for aluminum?
    OH
    1,585
    Quote Originally Posted by tjsb View Post
    Yes
    2,731
    I'm not familiar with farenheit, but is it possible that you meant 750f fweasel? I use 450c and that works fine, you just need a high wattage iron and/or a tip with a lot of thermal mass.
    You need flux for any soldering, but I use flux core solder rather the separate flux for electrical soldering, it is however specialist solder for aluminium rather than the usual 63/37.
    4,119
    Ah, my mistake, yes I meant 750F
    Aug 2021
    325
    Careful soldering lipos though, can be done but do not apply heat for longer periods, 5s is the comfort level. Lipos do not like heat and die plus if you melt anything by accident they might catch fire.
    Do it in a fire-safe environment. It can be done and it's safe if done right.
