Page 2 of 2 FirstFirst 12
Results 31 to 36 of 36
Thread: E1 Seabird
  1. #31
    Mar 2022
    Ls
    102
  2. #32
    Mar 2022
    Ls
    102
    Today's session didn't prove anything startling, but it goes well enough at half throttle. I am printing a huge spacer for next time so the jet outflow will be right out the water.
    https://youtu.be/SbCSUI2pgLs?si=svH8EVHscyhvuv77
  3. #33
    Mar 2022
    Ls
    102
  4. #34
    7,633
    Quote Originally Posted by Returntohome View Post
    Now she looks great in the water!! Really nice.
    So I guess the next question is runtime. Because I assume that is why the full-size went with the foils.
  5. #35
    Mar 2022
    Ls
    102
    E1 hydrofoil
    Testing on the lake yesterday, it wasn't what I was expecting, very unstable. It took me all morning to realise what was wrong, I kept noticing a silver stream from the right foil under the water, added to which more spray on that side. So when I moved them forward the right side must have been set at a steeper trim angle. I needed a way to prove it, I decided I needed to hang the boat from it's nose which turned out to be very easy and effective, see photo. With my biggest set square I found the right foil to be 2.5mm further forward. I now have a way to get them equally set up. Whilst hanging I noticed some distortion on the surface, which must have happened due to travelling at speed under water . Luckily I made the sections removable, so it was easy to file and sand then repaint.
    I will add yesterday's video, see if you can see what I saw.
    https://youtu.be/LiIbwDoU9fc?si=30SmtjKeUnzvXQMb20240505_162154.jpg
  6. #36
    7,633
    Yup it does definitely look like one side is up ahead of the other. And a little spray here and there ahead.
