Results 1 to 2 of 2
Thread: 114cm cat newb questions.
Hybrid View
    Feb 2023
    ON
    122
    Default 114cm cat newb questions.
    -MYSTIC 114CM HULL.
    -4092, 2000KV MOTORS.
    -42MM 45MM 48MM PROPS.
    1. WHAT SIZE BATTERY CAPACITY ARE BOATS THIS SIZE RUNNING?
    2. WHAT THE AVERAGE RUN-TIMES?
    3. CAN BIG CAPCITY (OR PARALLEL MANY BATTERIES) WORK, WHAT ARE THE AFFECTS OF ALL THAT BATTERY WEIGHT?
    4. DOUBLE OR TRIPPLE THICKNESS MOTOR-MOUNT PLATES. CAN THAT ELIMINATE THE USE OF THE REAR MOTOR MOUNTS?
    Cheers,
    Aug 2020
    Oe
    33
    5000mah a 6000mah max .2x 6s each side one battery.
    Verstuurd vanaf mijn CPH2409 met Tapatalk
