Mic Halbrehder
IMPBA 8656
NAMBA 1414
Interested in 6/7, who prepped them?
Sent from my SM-S908U using Tapatalk
1-7 are all my prep.
Mic.
Mic Halbrehder
IMPBA 8656
NAMBA 1414
I’ll take 6 & 7 if available
6 and 7 spoken for Papote611
Mic Halbrehder
IMPBA 8656
NAMBA 1414
Sorry, I'll pass.
6 & 7 shipped
Mic Halbrehder
IMPBA 8656
NAMBA 1414
looking for something like a 1712-17-45 if ABC made one,would the 1515 or 1516 work?
?????????? is the 1515 or 1516 less of a prop than 1714 ????
What is the price for #8 ?
ABC props are listed as (diameter)(pitch ratio) both in inches. So, a 1714 prop is 1.7" in diameter, with a 1.4 pitch ratio. The 1515 and 1516 are smaller in terms of diameter, but have more aggressive pitch. If a prop is too small for the hull its paired with, it won't push it and will just cavitate.
A 1516 is 38mm diameter with a 1.6 pitch ratio 38 X 1.6 = 60.8 mm pitch
A 1714 is 43mm diameter. 1.4 pitch ratio 43 X 1.4 = 60.2 mm pitch
hypothetically the same speed per rpm but the 43mm has much more blade area and will slip less. Your 1714 just pulling too much power could be cut several ways to increase slip or efficiency and make it act like a 1712 (less pitch) I would carefully take 1/2 - 1mm off the leading edged making a less diameter prop without disturbing the blade profile much. Your COB or center of blade pitch would be retained.
Mic
Mic Halbrehder
IMPBA 8656
NAMBA 1414
Got the props today. Very nice work done on them. Thank you. Can’t wait to use them.
