Results 1 to 7 of 7
Thread: Converting a Proboat Glow Hydro to Electric
    May 2016
    NM
    12
    Default Converting a Proboat Glow Hydro to Electric
    I have a Proboat Formula Boats glow powered hydroplane that I would like to maybe convert to electric. It currently has a .18 glow motor, and boat is about 26" long.
    What would be a good electric setup for this boat?
    Mar 2023
    tn
    538
    OSE raider 150a, leopard 3660 2050kv, two 2s batteries wired in series.
    boat is wayyyy cooler as nitro though.
    7,631
    Well since I have done several of these and am currently doing a Miss Bud I think that I would recommend a OSE Raider 90 ESC and 2200-2400 36mm motor for 4s or 2800-3000 for 3s packs. If you size packs well you can squeeze them into the sponsons for a 2p setup. 37mm prop is a good start. I should have the Homestreet build on here to check out.
    Shawn
    4,125
    Shawn
    Finally found a V2 miss bud with the stuffing tube and aluminum strut that I plan on converting. Never could bring myself to hack of the V1 hull I have hanging on the wall.
    7,631
    What’s the difference between V1 & V2 Ryan?
    4,125
    The V1 had the solid driveshaft with the V shaped support down the entire length of the tunnel and no strut at the back. The V2 hull had a stuffing tube, flex cable, and an aluminum strut mounted to the bottom of the hull.
    7,631
    Ah ok, I’ve got one of each then. Not that it matters now, haha
