Results 1 to 8 of 8
Thread: Double trouble 34 inch sprint cats
    Jan 2020
    Az
    515
    Default Double trouble 34 inch sprint cats
    Hey guys, I just scored an NOS 34 inch sprint cat on fleebay last week and now I have two of these things I want to build. The one I just got in the mail is an older version with the higher sides which makes it easier to fit batteries down in the sponsons and lower CG. The old dusty one is the newer version with lower sides and thus makes it harder to fit batteries. I was thinking of doing the lower profiler version as a speed run deal on 8s and the taller version as a boat for handling well with still a decent amount of speed. I am wondering what I should run for electronics in them so I am looking for recommendations.
    Mar 2023
    tn
    538
    TP 4080CM 2022kv with castle xlx2 would be a pretty good setup for speed
    Jan 2020
    Az
    515
    That would be cool, maybe a 6s deal you think?
    Mar 2023
    tn
    538
    Jan 2020
    Az
    515
    Man that would be some serious rpm there!
    Mar 2023
    tn
    538
    thats actually the low RPM option. The 2350kv is a WYE wind and probably a better choice. 66k RPM under load. Motor is rated for 68k sustained with 11kw peak. Should be able to do at least 125mph.
    4,119
    Hit up Tyler Garrard for advice on setup with this hull.
    Jan 2020
    Az
    515
    Here?s some motors just to see the room I have. One is an NEU 1530 and the other is an NEU 2215. Seems like it may be a little tight with the 2215 and also looks like I need to get rid of the rails possibly.
