Results 1 to 5 of 5
Thread: Anyone change the caps on a spectrum 120
    Mar 2023
    124
    Default Anyone change the caps on a spectrum 120
    Looks like the caps are blown on mine purchased it used, the caps are bulged on the ends thought I might try replacing however they are not available by any numbers on them
    4,125
    Those are ZLH series caps made by Rubycon, which are easy to find. You need a minimum voltage spec of 35V. Existing bank is 1170uf total, so I would probably use 500uf as a minimum on the replacements since this is a low current capacity ESC.
    Mar 2023
    124
    Thanks for the reply, I jumped a bit too fast on this subject, I found them on e bay ��
    Aug 2021
    325
    Get more of them else you will blow them again.
    You had too much ripple which overheated the caps. Put 5 or 6 in parallel.
    Mar 2023
    124
    I purchased 10 of them, thanks
