Two Hyperion Chargers, 24V Power Supply, in a Pelican Box.
SOLD
Two EOS0615i Duo3 chargers[/B]
#2 & #3
The specifications are as follows:
Requires 11V-26VDC input.
Total Output Power: 180W + 180W
Discharge 50W + 50W
LiPo 1s-6s
LiFePO4 1s-6s
NiCd/NiMH: 1-16 Cells
Lead-Acid: 1-12 cells
Balances a pack down to 0.002 Volts between all cells in the pack.
Includes alligator clip adapters, Hyperion 2s-6s balancer adapter, and battery plugs.
Will come with what is in the Picture for each charger.
Chargers have been upgraded to the latest firmware.
Q - I was asked why the 2 and 3s ports on the balance boards are taped off?
A - I did this because I only have 4 and 6S packs.
A - the black electrical tape can be removed to use the 2s +3s ports.
24 volt Power Supply (NEW) 24 Volt, 1000 Watt, 41.6 Amp.
Has a switch for 110 V. or 220 V. Input
Fine adjustable output voltage.
3 - 24 Volt outlets. Stainless Steel with a large built-in fan.
Pelican Box
From Progressive RC - 15" L, 12" W, 10" H,
110V - AC power plugs - into the back of the Pelican Box
4" 110 V. Fan with blade guards inside and out.
One charger mounted on the inside of the lid, the other mounted on the false plywood floor above the power supply.
$220. USD + shipping from Niagara Falls, NY. 14305 for US buyers.
Also 1 extra wiring kit. for $12. USD
2 - charge boards 2s - 6s with plug wires for the chargers.
1- Series board with plug wires for the chargers.
1- set of wires for charging two 2s packs in series as a 4s pack.
1 - charging wire setup for transmitter + receiver packs.
1 - programming cable for Hyperion chargers.
