You can purchase replacement cables from OSE, and collets, although I see they are out of stock currently. Give Steven V an email perhaps.
You can solder the end of your shaft, in fact you should. I use a large electrical cable crimp as a pot, melt solder into it with a butane torch and dip the end of the cable in until it heats up and the solder builds up on the end. After it has cooled , I chuck the shaft end of the cable in a cordless drill and use some sand paper to on the end while running the drill to remove excess solder and size it to fit the collet.
Another trick for the collet is to put some antiseize on the thread, I use a copper coat one. This helps to prevent the threads from picking up and makes it easier to do up and undo.
