I have four EOS0615i Duo3 chargers for sale.
The specifications are as follows:
Requires 11V-26VDC input.
Total Output Power: 180W + 180W
Discharge 50W on each output
LiPo 1s-6s
LiFePO4 1s-6s
NiCd/NiMH: 1-16 Cells
Lead-Acid: 1-12 cells
Balances a pack down to 0.002 Volts between all cells in the pack.
Includes alligator clip adapters, Hyperion 2s-6s balancer adapter, and battery plugs.
Each one will come with what is in the Picture for each charger.
1,2, and 3 will come in original boxes.
All chargers have been upgraded to the latest firmware.
$55. USD + shipping from Niagara Falls, NY. 14305
Also 1 extra wiring kit. $12. USD added to any one of the chargers.
2 - charge boards 2s - 6s with plug wires for the chargers.
1- Series board with plug wires for the chargers.
1- set of wires for charging two 2s packs in series as a 4s pack.
1 - charging wire setup for transmitter + receiver packs.
1 - programming cable for Hyperion chargers.
Deals available for more than one or everything at once.
Q - I was asked why the 2 and 3s ports on the balance boards are taped off.
A - I did this because I only have 4 and 6S packs.
A - You can remove the tape to use the 2+ 3s ports.
