Results 1 to 8 of 8
Thread: Self build jet outboard
    Mar 2022
    Ls
    100
    Default Self build jet outboard
    https://youtu.be/kYGZzhqawlA?si=kO_Yxs1lYvnpHFQv
    I developed these using some parts from my prop outboards. They are a copy of the full size version used on very shallow rivers.
    See photo below.
    Mar 2022
    Ls
    100
    Mar 2022
    Ls
    100
    7,630
    That is killer. I’ve seen some of the 1:1 outboard jets over here on the west coast of Canada
    Mar 2022
    Ls
    100
    Glad you like it, I surprised myself at how well it worked, an element of luck.
    Mar 2022
    Ls
    100
    I did all my development using my own 3d printed impellers of all different sizes and pitches. Then I had this one printed for me in China made from aluminium.
    It's brilliant, much stronger with less flexing which gives lower amps. I bought two, one for another engine fitted to an rib.
    7,630
    Quote Originally Posted by Returntohome View Post
    Mm, a screw design. Have you tried this yet?
    Mar 2022
    Ls
    100
    So in the canal video it's a metal impeller, the other video it's my own plastic, so not a massive difference. The best thing is durability, no broken blades on the metal one. Pcb way is the company, I sent my file and 2 weeks later I was using them, great service. During the canal run the chamber split so water sprayed out, huge pressure in there. I am printing new parts at 100% fill to make it stronger. Also I didn't know the metal impeller was a bit loose, that's where the wear ring did its job of protecting the casing.
