What I have done on many boats is cut a piece of carbon cloth to fit inside the transom, stand the boat up on it's transom and fill it with epoxy resin enough to cover the cloth. By standing the boat flat on the transom this gives a nice flat surface inside and extra strength. In hard to get to areas I will also glue in some 3mm ali plate and drill and tap.
This system works really well if it is a used hull and you are re doing hardware. Just tape over all the holes and allow the resin to fill them up.
