Results 1 to 16 of 16
Thread: how to square flex cable/which cable?
    Jan 2008
    543
    Default how to square flex cable/which cable?
    Hey guys I need some help. I am trying to square some .187 flex I bought here on ose. The ose cable seems to be stiffer. The cable that comes with my outboard is more flexible and seems to be a finer wire. I have a press and a die that I made to square the ends but the cable seems stiffer than the one that comes with my outboard. I am making my own cables because I am building my own lower from scratch.
    Any ideas on where I can get the finer cable or tips on squaring?
    Thanks,
    Rich
    24 R/C vehicles and still counting...What budget?
    Mar 2020
    NH
    326
    TFL has them also ,look at tfl-hobby.de you can see what they have ,then oder it from a tfl dealer near you
    Jan 2008
    543
    Quote Originally Posted by koen View Post
    Thanks for the reply Koen, it looks like they also have both left and right lay cable as well. Do you know of any distributors in the usa?
    Aug 2021
    325
    Might ask either one below, I'd order from aliexpress directly. Typical 2 week ship.
    No way for you to run round ones? Makes life so much simpler, I typically tin the ends, which is easy to do.
    https://tflnorthamerica.com/
    https://www.instagram.com/angeljnaveda/
    0.187 is 4.76mm, can't tell what length you need. Below link is only as a guide, wrong diameter
    1PCS TFL 2.2/3.17/4mm Flex Cable Drive Shaft Dual Round/Square Round/Dual Square Length 300mm Spare Parts for RC Electric Boat - AliExpress
    4,125
    I believe square cable ends are done with a die and press, not something you'd be able to accomplish yourself in a home workshop.
    ca
    6,963
    Jan 2008
    543
    I have a press and a die. I work in a fabrication shop. I'm just worried the stiffer cable will be problematic.
    Thanks properchopper I'll see what he can do for me.
    ca
    6,963
    Quote Originally Posted by Rich View Post
    OOps - Frank
    Feb 2019
    385
    Did you try heating the flex cable end and heating the die before putting it in the press? Might help.
    Jan 2008
    543
    OOps - Frank
    Haha good thing I didn't call him yet
    Quote Originally Posted by 1coopgt View Post
    Thats not a bad idea. I might give that a try until I can call up Frank at hyperperformance.
    Jan 2008
    543
    OOps - Frank
    Properchopper, have you contacted Frank recently? I called him and place an order but haven't been charged yet for the cables and I have left 2 messages with no reply. Not trying to bash or complain about him just curious if he has something else going on.
    ca
    6,963
    Rich,
    Can't really say, don't know, haven't seen him at the lake for quite a while. I'll call & see what happens.
    Jan 2008
    543
    Rich,
    Thanks I appreciate it! I hope he's ok.
    Jan 2008
    543
    Rich,
    properchopper did you by chance get a hold of him?
    Feb 2016
    64
    The square of the cable will cause it to be stiffer. It's not a problem if straight, but if a radius is near the square end it will whip. Just something to keep in mind. The finer strand on the original helps stay flexible.
    Jan 2008
    543
    Rich,
    It looks like he got to them, he charged my card.
    Quote Originally Posted by Silver954 View Post
    I ran one of my cables in a test tank and it loosened up a bit so we will see what happens with the other cable. I have cables made and will see what happens.
