Results 1 to 2 of 2
Thread: Pro Boat Recoil 2 V2 26" Self-Righting Brushless Deep-V RTR, Shreddy
    Mar 2018
    NY
    36
    Default Pro Boat Recoil 2 V2 26" Self-Righting Brushless Deep-V RTR, Shreddy
    This boat is in excellent condition. Used very little.
    Mad Lizard Turn Fins and Trim Tabs have been installed.
    Asking $275. Batteries are available if needed.
    The boat is located in Canandaigua, NY
    Features
    ? High-impact ABS molded self-righting hull and canopy
    ? Spektrum 2300Kv Brushless Outrunner Marine Motor with integrated weight
    ? 100A Spektrum Brushless ESC
    ? Two custom liveries by Shreddy and Heat Wave Visual
    ? Aluminum offset rudder and propeller strut
    ? Flex shaft-driven propeller
    ? Stainless steel hardware
    ? Durable aluminum propeller
    ? Custom-programmed Spektrum SLT3 3-channel 2.4GHz transmitter and receiver
    ? Pro Boat 5.3kg waterproof servo
    ? Flotation foam on the canopy and hull
    ? Battery tray with new second battery strap
    Thanks for looking!
    Mar 2023
    AZ
    124
    Do you still have this
