Results 1 to 6 of 6
Thread: Futuba extended RX antenna's
    May 2009
    UK
    1,018
    Default Futuba extended RX antenna's
    Hello,
    Does anyone know where to get either the FUTRXANT500 or the FUTRXANT400 ?
    I tried to make contact with a gent selling them on int waters but apparently im a robot and not allowed an account over there...
    Could someone also clarify if they work with the 7PXR compatible rx's ? i.e. r304sbs / r334sbs etc
    Cheers, Liam
    Uk SAW record holder
    May 2009
    UK
    1,018
    As in attachment
    2,731
    I'm not familiar with the RXs you mentioned, as I run Futaba air based stuff, but every Futaba RX i have used has the antennas on the U.fl connector. Same for Frsky and Radiolink.
    I believe its an industry standard, the only RXs I have used that didnt have U.fl were some terrible early spektrum car stuff that was soldered direct to the board, and with the quality and cost of your boats, if your RXs dont have shielded connectors I'd flog that radio on ebay or consign it to landfill and upgrade.
    Here is a 400mm futaba aerial with a U.fl
    Feb 2016
    64
    Also if you contact futaba they sell them directly.
    OH
    1,585
    They are just laptop wifi antennas. Go on eBay or Amazon.
    Feb 2024
    WA
    The 7PXR is a surface transmitter that is compatible with various Futaba receivers, such as the R304SB, R334SBS, R2106GF, and more https://futabausa.com/product/7pxr/ basket random.
