Results 1 to 23 of 23
Thread: Salt Water bath?
    9,402
    Default Salt Water bath?
    Lots of packs to euthanize and I am curious as to how much salt to use to kill some packs. How many packs can I soak in this one bath and how do you dispose of the water after?
    Any other info is appreciated. I use my discharger and ISDT Q8 charger to bring them down to zero. The charger has a neat "KILL" funciton.
    Mar 2023
    tn
    538
    I always just charge them fully then put in a bucket of diesel soaked ammonium nitrate use for target practice.
    9,402
    LOL, Thanks for making me laugh
    2,913
    Ray cut the power wires off of them also the balance wires. (one at a time)
    If you don't have a use for them - give them to me.
    Cover with water and about 1/2 cup of salt, let sit for a week the into the garbage.
    Oct 2015
    174
    Somewhere I read a pound of salt for 2 to 2&1/2 gallons of water. DO as Truckpull says, and cut the wires off. I have done as many as 3 at a time, in a 5 gallon paint bucket. If you buy the salt " Mortons " the containers at the
    supermarket are 1 lb. I flush the used water down the toilet.
    Sep 2020
    Tx
    286
    I just hook up a automotive headlight bulb to the mains, and go leave it in the driveway on the concrete for a little while. Drains them right down. Haven't had one do anything during that other than puff and swell a lot.
    Jan 2023
    GA
    202
    That’s what I do as well. I use two old-fashioned automotive headlight bulbs wired in series. That will drain them down to zero, and the packs will puff right as they hit that zero mark, but they have no energy left and are inert at this point so nothing to worry about with the puffing
    The salt water bath is actually a misused myth that has been passed around for years. If you read the document where that concept originated from, the instructions are to put them in the salt water bath only AFTER they have been fully drained.
    Placing Lipo‘s in a salt water bath causes the cells tab connecting them together to be eroded away relatively quickly, meaning you may or may not get a voltage reading on the mains anymore, however, the cells still have plenty of energy left in them and are not inert from the salt water bath alone
    Aug 2021
    325
    Saltwater is an old thing that just won't die. It's silly to waste the salt.
    Discharge with a lightbulb or load, as per above, and just throw them away. I always twist the leads together once they are empty.
    Saltwater is as useful as blinker fluid.
    9,402
    Lol.... lots of info here, thanks!
    2,913
    Run them down with your discharger, Cut the wires off, if you want proof that the salt water works.
    Slice the coating on the cells. so that the foil on each is split open, to let the water into the cells. When the saltwater soaks in, they will start to bubble.
    This is killing any type of power left in the cells.
    Let them sit for a week.
    To do multiple cells, use 1/2 cup.
    Aug 2021
    325
    Slicing alone will do that, no saltwater needed. Not needed if you discharge them to zero. Waste of time and effort but it will make bubbles.
    9,402
    Advice taken..
    Q: Eight year old Revo cells, 6S Puffed, 6.6mO per cell, Should I kill them?
    Apr 2020
    702
    Advice taken..
    How badly? Photo?
    9,402
    Quote Originally Posted by Panther6834 View Post
    How badly? Photo?
    I'm destroying them, one down for now. Too puffy. I'll try to get a pic before I kill the second pack.
    Apr 2020
    702
    If they're not overly-puffy...particularly 2S & 3S...I usually hold onto them, for testing new ESCs & motors when installing them. But, those ones never leave the house - they stay right near my RC workstation.
    9,402
    I went through all my 4S packs. 2 out of 10 were crap so I can use the rest for sport running and testing. So far I have 4 packs discharged and shorted out, outside. When I get some salt Ican finish them off.
    Aug 2021
    325
    Might as well use pepper to go with it, has the same effect.
    This salt myth is truly hard to kill.
    If they are discharged, there is nothing else that will change anything.
    2,913
    Quote Originally Posted by jkflow View Post
    If this is true, Why did my pack, that I discharged to Zero, Cut open and sliced each cell with an exato knife.
    Puff all cells when put in salt water for 4 days? They also pissed a white foam on top of the water.
    Apr 2020
    702
    [QUOTE=TRUCKPULL;769324They also pissed a white foam on top of the water.[/QUOTE]
    That was the meringue, for the pie.
    Aug 2021
    325
    Simple chemical reaction between the materials and salt water, but other than foaming, what did it actually do beside make a mess?
    Answer = nothing.
    I can't make you stop what you are doing, but please understand that it does nothing to the lipo that will make it 'better' or 'safer' or whatever the myth is out there.
    Only trying to educate.
    Salt water as a 'solution' came about in the early lipo days as the conductivity helped discharge the lipo, that is easier accomplished by a simple resistor/light bulb.
    If there is no reaction when you slice the cells open it's already chemically neutral, it will still oxidize, which is normal and yes it will be faster if you submerge but doesn't accomplish anything useful.
    Convince me otherwise. Bubbles or white foam accomplish what?
    Apr 2020
    702
    If it wasn't obvious (and, I can't see how anyone could have thought otherwise), my "meringue" comment was meant as a joke...as in, lemon meringue pie. It's called, "having a sense of humor".
    Aug 2021
    325
    Sorry, didn't mean to quote you but the one right above
    Apr 2020
    702
