Sammyha, check out the first page of the Lipo testing thread link below that has been running for more than a decade. These guys do yearly controlled load testing of a variety of packs due to the fact that C ratings are known to be marketing nonsense, and the maxAmps brand has been the running "joke" of the lipo world the entire decade they have been testing them. Thunder Power is also right there with them, and they have the same high price/garbage quality, preying upon the uninformed that will believe the marketing hype
They are bottom of the barrel, barely 15C garbage packs that are being sold at 2-3 X what far better lipo brands out there are sold for. The results on the first page are always kept up to date with the latest load testing, broken down into weight categories and what load each pack could handle without failing completely.
The Max Amps 5000 mAh pack lasted literally ONE second under a 125A load before the voltage sagged down to 3.7V per cell, and consistently comes into last place in their various testing. 125A currents are nothing for FE boats which usually average much higher currents. Compare that same 125A constant load test to an SMC pack that held for a whopping 71 seconds at that same load, and for less than half the MA pack cost!
https://www.rcgroups.com/forums/show...st-Comparisons
SMC is the current best performing lipo you can buy today, is US owned and based with actual customer service directly from the owner. Even "if" the MaxAmps was exactly as good as SMC (its nowhere close), you still paid 3 times as much as a same pack from SMC with much better performance would have cost you.
https://www.smc-racing.com/index.php...ry&path=67_119
