Results 1 to 3 of 3
Thread: Automotive class paint in a rattle can
    Jun 2010
    Mi
    738
    Default Automotive class paint in a rattle can
    Team,
    I fount a great product:
    SprayMax 2 component paint in a rattle can. Covers great.
    It is a urethane-based auto spray paint. There is an inner bladder that you puncture from the bottom.
    Flows enough to keep orange peel at a minimum. I do recommend painting under a bright light to see the reflection to avoid orange peel.
    Apply 2nd coat in about 10-15 min, or do a String test
    https://www.youtube.com/watch?v=s5GFRGhbzBI
    after you are done, store in the freezer to halt the catalytic reaction. Warm the can back up with a water bath before next use.
    Others have said they can use it up to a few weeks if stored in the freezer once mixed.
    It is not cheap, ($20+ a can) but if want great results and you don't have a compressor +gun + materials, this may be the way to go,
    I used a hi build primer, and sanded to 400 grit before the base coat.
    I use 1K (single component) base
    https://www.66autocolor.com/collecti...ve-spray-paint
    sand with 600, 800, 1000 grit as prep for the clear coat.
    I used a 2K (2 component) clear, good for marine environment:
    https://www.66autocolor.com/collecti...r-coat-aerosol
    Im impressed. fantastic shine, and a polish able surface just like an automotive pant.
    Oct 2021
    WA
    14
    Larry, I plan to use SprayMax on an LSH I'm finishing. I've read in several places that this stuff is pretty nasty. I have a 3M half-face respirator but I'm not sure which cartridge would be best. 3M doesn't make a recommendation other than using a supplied air system. What did you use and how did it work?
    Does anyone else have suggestions? Thanks!
    Feb 2023
    ON
    127
    Hello folks. I'm going to try the Endura 2k aerosols in time. https://www.endurapaint.com/product/...ol-spray-cans/
    Will let ya'll know how well they spray.
