Results 1 to 5 of 5
Thread: Blackjack 24 throttle is getting stuck wide open
    Jun 2023
    AR
    3
    Default Blackjack 24 throttle is getting stuck wide open
    I recently upgraded my blackjack with an ose raider 90 esc and leopard 2750kV motor, running a 42mm cnc prop, 3s, stock receiver set up(srx 200). Today on the second outting, i was wide open and the boat stayed wide open until i threw it in reverse. It did this a few times. Im just curious if its an interference issue, esc issue or receiver issue. Any help would be appreciated. The set up has only had 3 5000 50c batteries ran through it. Thanks!
    Mar 2023
    tn
    538
    receiver getting wet?
    Jun 2023
    AR
    3
    It had some moisture on it. I was thinking with the raider?s signal loss protection should have prevented it but if the receiver was geeking out it probably wouldnt.
    Mar 2023
    tn
    538
    Wrap it in a balloon put 2 zip ties on the end.
    Jun 2023
    AR
    3
    Thanks!
