Results 1 to 10 of 10
Thread: TFL 1151 Electric Jet Racing Boat with Thruster ARTR
    Mar 2023
    ID
    165
    Default TFL 1151 Electric Jet Racing Boat with Thruster ARTR
    Anyone have this boat ? many questions, well only one or two , can the jet prop be upgraded? I am looking for a platform to build a retriever boat.
    Apr 2020
    CA
    702
    Quote Originally Posted by paulejr View Post
    Have one...and, yes, the impeller (is not a 'propeller') can be "upgraded". But, you have to understand what, specifically, the upgrade is, and what is does. The stock impeller is a 2-blade, with a high pitch (2.185", OSE part number cnc-2919250). It is designed to "push through" water at a (somewhat) high speed, but with less torque. The "upgrade" impeller is a 4-blade, with a pitch that, physically, is half that of the 2-blade...but, because it's a 4-blade, the listed pitch is identical (2.185", OSE part number cnc-2919450). It's designed to push water through at a lower speed, but with more torque. Or, maybe I've got these two backwards...brain is a bit "out of whack" right now.
    The point is, the actual end-performance of both impellers is about the same. It's been a couple years since I tested them back-to-back...but, to the best of my recollection, the boat's performance was about the same. On the 'plus' side, Steve (ie. OSE) does sell them...and, he has both impellers in-stock right now.
    Mar 2023
    ID
    165
    Got it. I am guessing you used a 11.2 volt battery? I have a couple of G2's and will use just one at 3s , at 50c (huh) 22.4 v 5000 mah. do you remember what power you used on it? I believe the rpm at around 61,570 minus the slippage. sounds a bit high? hmmm , 11.2 v 50c , 5000 mah , 3s about half that ... the ESC rated at 120A. I will leave the impeller alone for now...
    Apr 2020
    CA
    702
    I run 3S & 4S. With other boats, going from 3S, to 4S, typically causes a sizable speed increase...but, 4S doesn't give it any huge speed increase over 3S, so just be aware of that.
    Mar 2023
    ID
    165
    Good info. Thanks. I decided to get this used one and set it up for a retreviral boat. The stock drive train should be enuf with what I have for a battery.
    Apr 2020
    CA
    702
    That's exactly what my intended purpose was for it when I ordered it. Unfortunately, having no reverse, using it as such was impossible (however, they do have a reverse upgrade). Additionally, the moment you let off the throttle, you also instantly lose steering, as the jet stream is part of the steering. But, used just for fun, is a blast. I've even gone so far as to try and purposely flip the boat...and, I've been unable to.
    Sep 2012
    Tg
    1,441
    The unit is rated for 25k rpm!
    Mar 2023
    ID
    165
    So, then , a couple of trip A's ought to do the trick....
    Apr 2020
    CA
    702
    Only if you only want 15 seconds of runtime...lol
    Mar 2023
    ID
    165
    Humpf.....
