Results 1 to 3 of 3
Thread: MG24 drive shaft replacement
    Jun 2023
    LA
    4
    Default MG24 drive shaft replacement
    The u-joint on the flex shaft broke on my MG24. I cannot find a replacement for this because it has been discontinued. Does anyone know is the flex shaft for the blackjack 24 will work in the MG24? Or does anyone have any idea where I might find a replacement? The part number is PRB0507.
    4,128
    The Miss Geico 24 used an integrated strut/rudder combo with a U joint on the end of the flex cable. The Blackjack 24 used an independent strut and rudder setup with a conventional flex cable and solid propshaft attached. The parts are not inter changeable. You could probably retrofit the Blackjack 24 strut and flex cable onto the MG24 hull along with a similar sized rudder, but I think the transom on the MG24 was narrower and there might not be enough real estate to mount it all.
    Jun 2023
    LA
    4
    Thanks for the reply. I will need to do some research on my end to figure out if that is something I am going to be able to do myself?this rc boating is new to me. thanks again!
