Results 1 to 7 of 7
Thread: Mini Dom or ten shock Mini Scord questions
    Mar 2023
    AZ
    124
    Default Mini Dom or ten shock Mini Scord questions
    For you guys running these boats what kind of life expectancy do you get out of your shaft and bearings and what are you using for lube and how often do you lube up.
    Also what prop do you like the best for just bashing around, I purchased a Oxidean 32 1.4 pitch I wanted a 1.9 but they were sold.
    Jul 2023
    Fl
    4
    Jul 2023
    Fl
    4
    Pull the drive out after a few runs.The tubes will collect water. Drain.. A drop of oil on each bearing and shove it back in. A bit of a grease "packing" at the aft end to help keep the water out and youre good to go.
    Apr 2024
    CA
    Are the products here genuine and warrantied?
    Jul 2023
    Fl
    4
    Bill, They every bit as genuine as yours.
    Jul 2016
    4,124
    Quote Originally Posted by Turbinator View Post
    Mar 2023
    AZ
    124
    I’ve purchased 3 of them from Tenshock they are exactly the same, just like Dymotorshop is the exact same Dominator.
    these hulls can all be purchased on Ali Express also for a 1/3 the cost never had a problem my DY motor shop hull came in 5 days to Arizona
