Page 1 of 2 12 LastLast
Results 1 to 30 of 35
Thread: advice on 1300mm 12s twin cat setup... NEED FEEDBACK PLEASE!!!
    Jul 2022
    4
    Default advice on 1300mm 12s twin cat setup... NEED FEEDBACK PLEASE!!!
    MHZ 1380mm, running 12s twin elec. TP 5850's 990kv on Swordfish 240's an ready to purchase props an the MHZ drives are 1/4". Are people turning down the shafts to 3/16ths" to be able to have smaller prop choice? most 1/4" props start at 67mm an up, which seems much. advice an info is greatly appreciated.
    4,119
    Quote Originally Posted by uncle marvin View Post
    you can find ABC props in the 2.1" and larger range, which is 55mm for 1/4 bore. Something like a 2114 might be a place to start.
    Mar 2023
    ID
    165
    Or , you could cut down a cheaper prop to the size you want, polish, balance, sharpen and maybe even try cupping and cutting the trailing edge by the hub. You can, kind of experiment on a cheaper alum prop to see what you can learn. Just a thought. Kinda like this : VXP BV642/2 42mm 1.6p 4.76mm B Cup Non Lift CNC Alloy Prop Boat Propeller MOD 3792769818350 |
    Mar 2023
    tn
    538
    drill out a 3/16 prop to 1/4
    Jul 2022
    4
    come to the same conclusion...... all summer try an try again. but i will know next summer.
    May 2009
    UK
    1,018
    Speak to chris hoffman, i know he did have some X470 R blanks, get one of them cut down to 57mm
    it's a hot setup so im assuming you want to go fast, later on experiment with some Abc props the 2115-17-45 is a nice prop on twins
    Uk SAW record holder
    Mar 2023
    ID
    165
    redrilling... huh, one needs a pretty good precision setup to insure it gets drilled properly, straight and square ...if you are off by more that a few thousands of an inch either way, the wabble will tear your boat apart (or drive line) before you can say fast electric.
    Mar 2023
    tn
    538
    Quote Originally Posted by paulejr View Post
    not really hard to drill square with a decent drill press. then you're only drilling 5-7mm. then you will balance it afterward. Id be more worried about not leaving enough material on the prop hub.
    4,119
    Square doesn't mean concentric too. New hole could be dead nuts on square and might never balance out. Safer and more reliable to just buy the right prop for the setup to begin with.
    Mar 2023
    tn
    538
    he cant buy the right prop, that's the point here. sometimes you have to adapt and overcome.
    Sep 2012
    Tg
    1,439
    Perhaps the op is best to either get another set of drive shafts already turned to 3/16", or get his existing ones machined down to suit.
    Mar 2023
    ID
    165
    well, he asked for suggestions , not stepping all over each other trying to be the only one right.
    Jul 2022
    4
    I got up with Mr Hoffman, an he sent out 2 sets to get me started. Any feedback is still great. Thanks to all.
    4,119
    Chis is a good place to start. What sizes did you order?
    Dec 2010
    3,119
    very hard to drill out a prop, tell me how you chuck it in a drill press ,, Iv try a few time , on a lathe and it's near impossible to do it square
    Mar 2023
    ID
    165
    Yea, I just wait and buy one , centering the hub on the chuck is tedious for such a small part.
    Getting the hub square and plumb to the jaws ..... You would have to build a jig to hold the prop and that, maybe tougher than just clamp it in a drill press vice , eye ball it and go for the gold.
    Mar 2023
    tn
    538
    put this on a drill press
    on a $30 milling table to aid in alignment with a .185 - .187 bit
    practice with cheap plastic props
    you can use a regular drill press vice and rotate the press table as well.
    a machinists centering bit would come in handy
    Dec 2010
    3,119
    yea lol good luck did you ever see a prop catch a drill bit , rip it out of that vise in a second , maybe those soft azz TFL junk but not Octura or ABC
    Mar 2023
    tn
    538
    This is a fun hobby to have fun with. Tinkering, tuning, playing. It's not serious business.
    Mar 2020
    NH
    326
    if you try to drill out a ss or beryllium prop keep a first aid kit close or 911
    Mar 2023
    tn
    538
    Quote Originally Posted by koen View Post
    why?
    OH
    1,585
    Just buy a turned down shaft. You are all over thinking it. Running 12s on 990kv motors is a lot of RPM. At least 45 volts right? 45k of RPM. I would start with about A 452 size. Those really big props can?t turn 45k. I?m not wrong either.
    Oct 2022
    56
    OSE sells 1/4' shafts stepped down to 3/16, I just got one 2 weeks ago. A much easier and better solution than drilling out the prop
    Mar 2023
    tn
    538
    Quote Originally Posted by Notoriousone View Post
    came to say the same...easiest thing to do right here
    https://www.offshoreelectrics.com/pr...e-cable-hp1300
    Dec 2010
    3,119
    well it's bad advise , & some one could get hurt trying !!!! & if you never tried to,,,, then you don't know
    May 2023
    17
    This might sound stupid in regards to drilling out a prop to accommodate larger shafts but to those that seem to think its an impossible task... How do you think they get made? I mean sure if you start with billet you have to start with center but when you start casting like most props are you do need to drill that hole correct?
    Mar 2023
    tn
    538
    Quote Originally Posted by Gottagobig1198 View Post
    You get these people in every forum. I think they just like to argue. lots of things with sharp edges that get drilled. You can tape up the edges, you can drill before sharpening, you can use a lexan face shield on the press. It's just nonsense and acting like people are 5 year olds.
    6,192
    Most hobbyist don't have the tools or skills to drill out a prop and even if they did......why would they? I've got a whole shop full of tools. I ain't drilling a prop.
    First the hub material left behind after drilling it out is very likely too thin to hold the blades. Especially at high rpm. These manufacturers came up with that hub thickness after years of failures. Speculation on my part to a degree but the hubs are of similar thickness on every prop. Accident? Wanna risk it with a cat that costs maybe a couple grand to build? If it throws a blade at those rpm it's like going to mangle something. Maybe the drive, maybe the boat, maybe the owner, maybe somebody standing watching? For what? To prove some dopes on OSE wrong?
    Second......why do any of that when the stepped shaft solution quite literally costs an extra $5 per shaft? So $10 for the desired result on a multi-thousand dollar build. What the heck are we even talking bout? Just get the right parts and use them as manufactured for fewer question marks. On a 12s beast you want the fewest "is that gonna work?" questions as you can. You want reliable with no surprises. Too many moving parts to take chances you don't have too.
    Noisy person
    Jul 2007
    or
    1,088
    If you don't want to go with step down shafts, I'd highly recommend 1/4 bore 2115-17-45 ABC's as a starting point.
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
    May 2023
    17
    I like doing R&D in the field. I can take every tool I have or a roll of duct tape and a hammer but I will make it work and work well!
