Results 1 to 20 of 20
Thread: Soldering T plugs?
    2,912
    Default Soldering T plugs?
    What is the best way to solder two plugs to an ESC in a "T" configuration?
    also how do you put heat-shrink on them?
    Apr 2020
    702
    What do you mean "in a T configuration"? Are taking about 'parallel', or 'in-series'?
    2,912
    Two sets of two plugs for Parallel connection. two 4S -5000 packs in parallel.
    2,912
    A picture is worth a thousand words.
    The red and Black wires are coming from the ESC.
    Apr 2020
    702
    So, parallel...in other words, the voltage into the ESC from two packs three same as the voltage from a single pack, but doubling the capacity (ie. the ESC will "see" two 4000mAh 2S packs as if it were a single 8000mAh 2S pack).
    Honestly, don't try to create this T design. You will be MUCH better off soldering a traditional parallel design, with each side (positive & negative) going to a Y, with the bottom of the Y going to the ESC, and connectors on each side of the top of the Y. See image.
    ca
    6,963
    Hi Larry
    a bit time consuming to construct, but way quick/easy in the pits :
    ca
    6,963
    2,912
    If you look at my picture below.
    I am thinking about turning on the lath, a piece of solid copper down to fit into the back of the plugs, and solider them so that they are toughing each other.
    I would then drill a hole the required size of the ESC wire, in the middle between the two plugs for the ESC wire.
    The other question then is how to shrink wrap it?
    Sep 2012
    Tg
    1,439
    "The other question then is how to shrink wrap it?"
    Liquid electrical tape.
    9,401
    You could encapsulate with epoxy.
    2,912
    I would still like to take it apart if I had to.
    2,912
    Quote Originally Posted by Panther6834 View Post
    Robb
    I have done my ESC's like this for years.
    I would like to try a "T" connection.
    Thank You
    2,912
    Hello Tony
    That is the right idea.
    But I would like it a little more compact.
    Apr 2020
    702
    Robb
    Thank You
    Got ya...no worries. Best of luck.
    2,912
    First part of my "T" connection is done.
    Copper pieces turned down and soldered.
    9,401
    One could bend the copper in the middle if it would make the setup easier to do plug ins.
    I have some 1/8" thick copper plate I was thinking of using in a similar way. I could cut some pieces in a "Y" shape or a "U" shape.
    2,912
    Ray
    These are solid slugs(no bending). They are going in front of the ESC, with the batteries on each side,
    So now I have + and - pointing right at the batteries.
    2,912
    I just put the wire in the hole, it is not soldered yet, because I have to shorten the ESC wires yet.
    For wrapping it, I am going to pick up some 3M electrical tape in Black and Red.
    6,191
    I use this to wrap anything that gets hot. Wont fail like shrink does. Stays put to 500 degrees.
    https://www.uline.com/BL_6422/Silico...=silicone+tape
    Noisy person
    2,912
    I tried this a few different ways, this is what I came up with.
