Results 1 to 4 of 4
Thread: 1/8 miss Budweiser replacement flex shaft
    May 2023
    SC
    Default 1/8 miss Budweiser replacement flex shaft
    looking for a stock miss bud flex shaft replacement for 1/8 scale ??
    any help would be appreciated
    Thanks Tim
    Mar 2023
    tn
    538
    why does it need to be "stock?" its just a .250 shaft. You order one and cut it down to the length you need.
    Sep 2020
    Tx
    286
    I used to have one of these. It's a different kind of setup. It is a square shaft at the collet, that terminates at the brass looking piece that has set screws in it just ahead of the strut. The prop shaft in the strut is a separate piece.
    You could easily convert it like the previous poster is mentioning, by moving to a round collet, buying a normal 1/4" shaft, and cutting to length. You would eliminate the two-piece design.
    Mar 2011
    BC
    7,631
    Look to a gasser site. Rocket City perhaps. The brass piece is called a ferrule and is a pretty common deal for back in the day
