Results 1 to 5 of 5
Thread: Swordfish 220a
    Oct 2010
    tr
    15
    Default Swordfish 220a
    Hello, I have a problem with my boat and hope someone can help, the motor wont start reliably, it will only start and run in a few spots, if you try and start it with the motor in the wrong spot the motor acts like a steeper motor, each time i pull the trigger it will advance a small amount, if you repeatably pull the trigger until it gets to the right spot it will start and run normally until you stop, the motor also seems to be getting quite warm, just testing on the bench, new motor.
    Sep 2020
    Tx
    287
    How many pole and kv is the motor, and what voltage are you running it on?
    There is a Startup option in the ESC, with options of Soft Start, Standard, and Fast Start. You can try playing with that. Motor may want a Fast Start setting.
    Oct 2010
    tr
    15
    4 pole, 1400kv, 22v. Ok will try that, thanks
    Oct 2010
    tr
    15
    She runs normally on soft start, both medium and fast the issue returns
    Sep 2020
    Tx
    287
    Well there ya go, run it on Soft Start.
