Lifting the bow, or lifting the stern?
IN the RC boating world, people usually say a lifting prop is lifting the stern.
Sounds like you may need a prop the provides more lift to the stern, forcing the front down.
The higher rake angle tightens the thrust cone, and makes a prop with less lift.
Most of the ABC props list their rake angle.
For example a 2014-10-50(2) CLL breaks down like this.
20 is the diameter in inches.
1.4 Pitch Radio
10-RAKE ANGLE
50-BLADE AREA RATIO
(2)-NUMBER OF BLADES
CL-CLEAVER OR CP-CHOPPER
L-LEFT ROTATION OR R-RIGHT ROTATION
A props Rake angle is measurable if the prop shaft horizontal.
I'm sure that someone on the forum has experience with this hull.
