Results 1 to 6 of 6
Thread: Quest. about solid drive shafts
    Dec 2010
    3,119
    Default Quest. about solid drive shafts
    Is it possible to use the solid drives in a cat with a S bend stuffing box ? Hmm ? thanks
    Dec 2009
    2,039
    How would a SOLID shaft BEND?? Most use the slightest bend possible.
    Sent from my SM-S908U using Tapatalk
    Dec 2010
    3,119
    Quote Originally Posted by oscarel View Post
    they do bend , that's why I was asking how much !
    4,119
    By solid drive shaft, are you referring to the piano drive steel wires? If so, I found them to be more trouble than they're worth in small cats with just a single bend, because it was too severe. I can't imagine an S bend setup would even be possible.
    Sep 2007
    2,783
    Chris, the simple answer is "NO". unless the S-Bend is very shallow and over a long length the wire will fail. Also the larger diameter the wire the higher the likelihood it will fail.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    Feb 2019
    385
    Your talking about a wire drive, correct? I suppose it depends on how drastic the s bend is.
