For Sale Castle Marine ESC's
All ESC's have been upgraded With extra capacitors
And water cooling plates on all Fet's.
Seeing that the original Hydra ESC's even the hydra 240 never came with water cooling on the top set of Fet's under the radio board.
The 5 Barracuda ESC's have all been modified with water cooling. Using copper plates and pipes.
All ESC's come with a plug taped off of the input battery power if you want to run a U-BEC.
With these modifications these ESC.s can put out a lot more Power.
The 80A Barracuda would now be 150A with the water cooling.
The 125A Barracuda's would now be 240A with the water cooling.
The 240A Hydra would now be 260A with the water cooling modification.
All battery plugs are 6mm.
All motor plugs are 6mm. except for the 80 and the 240
Motor plugs are 1/4" copper slugs, you solder your motor directly into one end and the ESC is soldered in the other end.
1- Barracuda 80 - (150A) -$75.00 (2-4S)
5- Barracuda 125 - (240A) -$110.00 each (2 to 6S)
1- Hydra 240 - (260A) -$135.00 (2 to 6S)
$10.00 shipping each.
Discounts for 2 or more purchases.
$550. for all 7 + shipping.
Instruction manuals will come with each ESC.
Larry
