Dues one grease the Teflon tube inside and out?
I try to make sure the outside of the teflon liner, and the inside of the brass stuffing tub are clean to prevent the liner from twisting or otherwise slipping out of position. I apply grease only to the flex cable and propshaft before installing them.
Or lose the teflon liner. You can use Merc marine grease, has teflon in it. Mix with OSE grease cause its thick! Put a small piece of water cooling tubing over the end of the stuffing tube where the cable comes out , stops water from coming up the stuffing tube. I just use lots of grease, good for three heats. no water.
J.
Well, that is what i thought. I greased the flex shaft thoroughly and put new Impulse 32 in water and within 2 minutes, the shaft got so hot the prop hub separated from the flex shaft ,came off in the water ( now at the bottom of the lake ) , all but about 2 inches of the Teflon turned into charcoal , the grease catcher melted and filled the boat with smoke. Upon further inspection, when i finally got the flex out of the tube, where the flex shaft that got melted into the brass plated steel stuffing tube, there is a burr where the factory attached the flex to the prop hub. Now, I know you are thinking I did not grease the flex, but let me assure you as one with slight OCB , i greased that shaft, and the noise it made just before I was about to bring it in to check temps, it died.
With a new cable I always go over the whole cable and stub with emery paper to take off any extras that may come with your cable. With up grade parts from ose you should have no problems. Factory parts are usually not quite up to par.
How many cells and what kind of RPM are you turning?
2 @3S wired for series . they rated at 11.2v and the motor is 2040 stock Spektrum = about 28,000 to 30,000 rpm less the slippage and I did not get a full run for the 2 minutes due to geese and some channel buoys. this was just shake down and it shook pretty good. it was all stock and the batteries are also Spektrum. not sure how fast as I forgot to turn on the gps speedo....
2 @3S wired for series . they rated at 11.2v and the motor is 2040 stock Spektrum = about 28,000 to 30,000 rpm less the slippage and I did not get a full run for the 2 minutes due to geese and some channel buoys. this was just shake down and it shook pretty good. it was all stock and the batteries are also Spektrum. not sure how fast as I forgot to turn on the gps speedo....<br><br><br>
Perhaps your stuffing tube and out drive/stinger are not aliened.
When i get to put this thing back together, I will check all the alignments again. Being a Journeyman Machinist ( Marine) retired, alignment is my middle name...Normaly,alignments are done ( up to) against the prime mover . in model boat case .. a real challenge to align all, once the stuffing tube is fixed by the manufacture in epoxy ... but, there is a dremel or two in my quiver
6s under load is at least 20v. So more like 40k rpm. That?s a lot for Teflon. It gets twisted up.
So, put the batteries in parallel to make 2 x 3S ? then closer to 22,000 rpm... or run without the Teflon? Or, huh I know I know, shim the factory tube (5/16ths) to run 1/4 inch flex and no Teflon ?
That is a very good question.
For most FE boats I would say don't use the teflon liner at all, remove it and get an OSE upgrade cable for your particular boat and use that with no liner. Just grease it well with a thick marine grease and you shouldn't have any problems
I have had others say the same thing. It may be a matter of each particular install. In this case after having a consult with a Navy A&E buddy, he thought the problem was the burr in the drive end as it only burned the back half of the teflon. upon scoping the stinger... scratched all to heck on the outboard bushing... I am ready to test again but will use the factory set up, new stinger, new teflon, new flex,dog,prop.
If you used the grease that came with the boat-it is defective, contact Horizon same thing happened to my Sonic Wake they replaced the boat.
- Was the liner actually good-quality Teflon, or cheap nylon? Sometimes it?s hard to tell them apart.I just had a liner melt. greased shaft day before with lucas marine grease and had 3 runs of 2-3 minutes each. 4th run 15 seconds in it melted. 4s with 2280kv motor....30k RPM under load.
- Was there evidence that the liner was spinning inside the stuffing tube? There?s a lot more friction between the liner and the tube than the cable and the liner.
- Was the cable removed and the greased prior to each run?
- Any evidence of cable fraying or swelling?
- How much of a gap between the drive dog and the end of the strut?
- Was a stop watch used to time the runs? It?s sometimes easy to be way off on time estimates.
1. it was from offshore electrics
2. no
3. no it was greased before the day. greasing after each 2 minute run is ridiculous and speaks volumes about liners
4. no
5. 3/16 gap with TFL stinger that allows gap setting quick and easy
6. yes. a count down timer on the controller is used and started by the trigger to time battery run time. set to 2:30 with 4500mah batteries. time between runs is 2c charge rate/30 minutes.
I use for flexible shaft Mobil 222 + WD40 50/50%. It won't be a very thick grease. Thick grease gives a strong load on the motor, liquid quickly flows out.
It is important to fix the teflon tube inside the brass one. You need to expand the teflon a little and insert it with force. Or fix the protruding teflon with adhesive tape or heat shrink with glue.
Melting a Teflon liner is actually pretty rare, so those experiencing issues must be doing something different than most other users. Not all lube is the same, lube meant for full-scale boats may not be the best choice for something it was never designed for. The higher the rpm and the longer the run time the more heat is generated. Cable with a rougher surface will also generate heat. Stuffing tubes not exposed to cooling water will get hotter than those which are exposed. Sharp bends in the tube will increase friction. All of these can contribute to melting the liner.
I haven’t run a Teflon liner in any of my oval or SAW race boats - other than a few stock RTRs - for decades. I run 3/16” cable in 1/4” brass tubing, using 70W synthetic gear oil as a lube. It’s been good to over 40,000 rpm in my record SAW boats and I’ve never worn out a brass stuffing tube even after years of use in the same race boats. This has worked well for me, but I caution others not to just remove the Teflon liner and run the cable in the existing brass stuffing tube. That is really too large in diameter and allows the cable to shorten too much due to windup. The cable should be somewhat smaller than the brass tube ID, but not too much smaller.
got back from the lake a few hours ago after replacing the teflon setup with 1/4 brass tube. This time I ran 6s for the first time at about 45k RPM. checked flex shaft halfway through the outting and it was smothered in grease and good to go. There's just so much more grease without the liner. What I bet happened to me is I ran low on lube. There's very little of it available with a liner. Im now firmly in the no liner camp.
Agreed, liners can be made to work with proper care, but they are really not needed and are a carryover from many years ago before high RPM FE boats were even a thing and a 50-60 MPH boat was considered very fast. There is a reason brass bushings are used in conjunction with steel shafts in many different applications, even high RPM uses like brushed electric motors. It acts like a bearing against steel, and will run for years without wearing out with the proper lubrication
OoooK! Summary from another newbie. I did RC planes, but that a different problem set. Here?s what I get from the discussion: no liner, flex shaft a close but not tight fit, well greased with a proper marine grease (I got the blue stuff with the pump), stop for a quick check reasonably often. Sounds like a plan.
