Results 1 to 4 of 4
Thread: charging 2s LIFe 6.6v 1450,mAH
    Mar 2023
    ID
    165
    Default charging 2s LIFe 6.6v 1450,mAH
    Help...how do I charge a Spektrum 2s 6.6v Rx battery on S155 ...has a balance lead and the plug in for the Rx but no charge lead ?
    FR
    2,094
    Same process than a LiPo battery, use the LiFe program and charge current max is the capacity.
    I use LiFe battery for the Rx, you will need an adapter for the balance.
    Mar 2023
    ID
    165
    ah ha, got thanks Alfa Spirit!
    FR
    2,094
    Here is the balance card I use, it works with many balance connectors. charging a LiFe battery use a charge lead like a LiPo battery.
