Results 1 to 17 of 17
Thread: 1/12 Homestreet AKA Miss Bud
    7,631
    Default 1/12 Homestreet AKA Miss Bud
    So this is what I have been working on this winter as time has permitted. I have 2 Miss Bud hulls. One is running in Miss Bud livery and the second was an unconverted hull with broken hatch. So I decided to build my own hatch addressing the water seal somewhat, and doing design changes as well. A bit of hull strengthening and aerodynamic changes as well as getting correct CG.
    7,631
    This is the start of the mould. And a comparison of the two
    7,631
    And a bit of the reinforcement that was done with 1mm CF, I also put a layer of cloth to beef up the floor. Also a 3? rigger motor mount with mods worked well up front
    4,131
    Love those side ribs. That hull definitely needs reinforcement. What are you going to run in it as far as kV and voltage?
    7,631
    My running one has a Castle 1512 2650kv in it and is real nice on 3s. A wobbly mess on 4s but I have a plan for that in aerodynamic area. This one is awaiting an afternoon for me to paint it so more updates are ready to post Ryan. You buying yours prompted me to do the thread
    7,631
    Oh and Ryan, 3300mah 3s packs down in front sponsons
    4,131
    Ha, that was my next question. Thanks.
    7,631
    And on that note, I installed a foam bed for batteries to sit on in the sponson bottoms followed by a piece that wraps the front and outside areas to keep the packs in place within each sponson. Also a piece of CF was added for the turn fin bracket to be threaded into
    And here is the complete plug and the first take
    7,631
    Here is my main change to aerodynamics based upon info from Mr Darin Jordan?s thread. The thought here is that too much air is getting pushed under the hull at speed there by causing the flutter effect in a straight line.
    Here is before and after
    Sep 2012
    Tg
    1,441
    4,131
    Plug turned out great. Interested to see how those leading edge extensions effect the ride quality. That would be an easy bolt on aero modification
    7,631
    As you can see from the one pic I had cut a couple pieces of hard foam to test on my Bud runner but water froze up on me. So I did the mod on this hull. But it took very little to carve the foam to fit and use double side tape to hold.
    7,631
    So I used this silicone Mold for the cowl
    And because I opted for a flow thru cowl I glued and epoxied this paper separator in underneath. It may need touching up for waterproof C98FAC32-0326-4C4B-99B0-2F105F850104.jpg
    And the hatch locks in in front and I made this body post work out back
    7,631
    Well got paint work done
    Decals pinstripes and clear done
    Stuffing tube to be installed next. But I went out to the hobby shack and my heater appears to be dead. Investigation is required
    4,131
    Looks great.
    7,631
    Looks great.
    Thanks Ryan, a little dust in the clear but it?ll wear off. So I got it wet! It seems good so far with a 637 on it
    7,631
    So I swapped out the 2400 kv Fiedler motor to 2800kv Hacker, 3s2p for total of 6600mah
