Results 1 to 25 of 25
Thread: MAD Racing Boat Worx 45 Sport Hydro put-together
    992
    Default MAD Racing Boat Worx 45 Sport Hydro put-together
    This will be the biggest sport hydro I’ve put together. I won’t be racing this in a sanctioned event as of right now. This is purely a fun runner.
    Any pointers or suggestions are appreciated!
    Laid up nicely in 12k Carbon Fiber:
    I decided to add a layer of 12k cf inside anywhere I could potentially place batteries:
    15ADEC50-DEFA-4839-A8A5-CF7B2D7FF5E5.jpg 4D0867CF-0B85-47C5-9BD5-3D4ED7109593.jpg
    With the added cf the boat weighs about 11lbs.
    RTR w/lipos it weighs just shy of 19lbs.
    I’ll try to keep it lite.
    992
    Debating on a few different motors:
    The one that looks like the best fit is the big Plettenburg: 6-8k watts
    I was hoping to get away with the Neu 1539, but it looks like a toothpick in there:
    The smaller Plett is similar to the 370S allowed for 1/8 scale hydros, but it also looks too small: 4-5k watts.
    Both Pletts are interchangeable 8s and 10s motors so that gives me some wiggle room for prop use.
    992
    Transom taped and strut installed. Speedmaster round bottom:
    Should I use a flat bottom strut instead?
    May 2009
    UK
    1,018
    What size is it? over in the UK im not sure what a sport hydro is, hardly anybody runs a hydro
    I've just had mine out, 10s and a out runner... running abc 1816 at moment, fast enough and can keep the throttle pinned for 4 mins straight without any heat build up
    Uk SAW record holder
    OH
    1,585
    Go with the big Plett
    992
    Quote Originally Posted by vvviivvv View Post
    It’s 45 inches long and is considered a sport hydro just like yours. I saw your boat a while back and loved it! How long is yours?
    992
    Quote Originally Posted by photohoward1 View Post
    That’s the direction I’m leaning toward.
    You have a couple pletts right? The 370S?
    OH
    1,585
    Quote Originally Posted by jingalls007 View Post
    That?s the direction I?m leaning toward.
    Yep
    992
    The sponsons have a step or strake. Not sure which one to line the turnfin to:
    267E327F-2CFB-4174-B75A-3E2B5B710043.jpg 208DE5BD-D373-4DE7-B36C-F197BF06D59C.jpg
    Any ideas?
    992
    Some 4lb foam in the nose and lining up the mount.
    6ED41767-0A33-4070-B562-28D5EE64CC4E.jpg ECDEF3F1-CA7D-4351-9FDA-BF47686130C0.jpg
    I don’t like the angle but the motor bottoms out if I go to steep.
    992
    Jun 2012
    ny
    1,135
    You sure that's not a 1530 neu? If it is definitely don't use that get rid of it, I'll take it off your hands. Ha Ha
    992
    Ha! It’s a 1539!
    992
    I couldn’t get the stuffing tube angle right with the stock stringers so I made a couple cf plate rail extenders:
    232396F0-B547-44A1-8527-9034B8EC2FA6.jpg 28ACB597-A99F-4985-9209-BE787D8B7202.jpg. 28A8956F-47EF-4BC6-B7E3-720AD95510F4.jpg
    992
    Yep
    Hold on to them. Plett isn’t producing private use motors anymore; commercial/industrial products only.
    May 2009
    UK
    1,018
    It?s 45 inches long and is considered a sport hydro just like yours. I saw your boat a while back and loved it! How long is yours?
    Will have to double check LOA but think it's around 40" ball park.
    I might try it on 12s on Friday ! has a YGE HV esc I have no idea about setup on these, hard to get it on the plane with the ABC props but once its moving, it runs beautiful.
    992
    This boat was designed around gas which makes it a little challenging to set up. The seller runs one (gas) and has been helpful.
    Yeah man, your hydro is one of the best looking sport hydros I’ve seen. It reminds me of a PT Hydro.
    992
    Strut and rudder centered and leveled:
    Attachment 176754. Attachment 176755
    992
    Hydra fits nicely in front of the motor:
    992
    Maiden today but, I couldn’t hold my phone and drive at the same time. I’ll have my wife video for me on the next one.
    If the hydra telemetry data is accurate the Plett pumped out nearly 12,000 watts (15 ponies) on 8s! Current peaked at 401 amps w/a 2515-17.45.
    I’ll make some adjustments to loosen it up a little bit and hopefully get the current down.
    May 2009
    UK
    1,018
    Congrats on the run, 2515 pair is my go to prop on my C5008 my poor little Hydro is only spinning 47-50mm props, you have a monster there!
    May 2009
    UK
    1,018
    whats the KV on the big plett?
    992
    Hey thanks!
    It is 950kv.
    992
    Trying to film and drive at the same time and the picture quality isn’t great (how do I adjust that?).
    Maiden (sort of haha):
    https://youtu.be/FQS8QJegFfs
    992
    And my newly rebuilt and modified R42:
    https://youtu.be/SeFtbrsbmpA
