Do you know how to setup a stinger for a mono hull with an in line rudder?
Same as normal. If you have that much prop walk then you can shim one side, but you may have other issues if that is the problem.
I prefer the in line rudder with 0 trim and same weight on both sides.
I made a search for this setting on FSR boats but I didn' t find.
