Results 1 to 6 of 6
Thread: Help with prop size?
    Mar 2023
    3
    Default Help with prop size?
    Need help sizing a prop on a Blackjack 42 running a TPPower 4070 motor with a Castle XLX2 ESC .Batteries are 2 14.4 100 c 5000 ma in series or 8s.8mm bullets and OSE 8 mm connectors.Is a 1.6 x 42 enough prop? All help appreciated.
    Feb 2010
    Ny
    478
    Quote Originally Posted by Farkel View Post
    Check out the YouTube channel Ironclad rc has your answer.
    Do you know what the biggest problem with the world is?
    That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
    Feb 2010
    Ny
    478
    What’s the kv on the motor? That would be helpful to know. If you’re using a Tp 4070 1520kv. On 8s then a 42 mm prop would make a good start, and check the temperature. download the Data Logging, then you can consider upsizing
    Mar 2023
    3
    Yeah,sorry.the motor is 1520 kv.Thanks for the help.
    8S is far too much for a 1520 Kv motor. Even 6S is pretty high for a 43” boat. A 4070 motor is pretty small for a boat that large too, if he wants to upgrade the boat’s performance there are better choices. And a 42 mm prop is pretty small for much efficiency, a lower Kv will allow a better prop. The OP really needs to rethink his entire drive system.
    Mar 2023
    3
    I am having difficulty reconciling your comments with the Owners Manual for the Blackjack 42.The manual states that:
    1) the factory installed motor is a 1350 Kv Spectrum;
    2) the factory ESC is 160 A;
    3)the batteries to be used for propulsion are 2 14.8V,5000 ma 4S1.6 100c packs in series as this is the way the boat is factory wired.
    4)Stock propeller is 1.6 x 42.
    With this S
