Results 1 to 13 of 13
Thread: Floating Strut
    992
    Default Floating Strut
    I’ve searched the forums with no luck; I remember seeing a couple threads that detail how to make a floating strut for a mono, but I can’t find them.
    If anyone has a link or can point me in the right direction I’d be grateful. Thanks!
    Jan 2020
    Az
    514
    I have a boat that I can show you how it is done.
    992
    Quote Originally Posted by BlakeT View Post
    Sounds like a plan. Thanks dude.
    Sep 2012
    Tg
    1,439
    Quote Originally Posted by jingalls007 View Post
    Do you mean a flood tube?
    992
    Peter, yes. I found a few more imbedded posts on the subject, but no instruction. Jesse J, I thought, started a thread on the subject but not sure.
    Sep 2012
    Tg
    1,439
    Sep 2012
    Tg
    1,439
    I did it also on my Cyberstorm with a stinger.
    It is a little hard to see. However you basically glue in a tube through the transom that allows vertical movement of the stuffing tube. The inside end needs to be sealed, I usually make an aluminium cap with a hole for the stuffing tube and glue it all together when lined up.
    992
    Quote Originally Posted by Peter A View Post
    Seems easy enough. I wanted to know how to seal off the end so water doesn’t get in. Just as simple as an end cap. I didn’t know you could also do it with a stinger. That’s a great idea.
    Thanks Peter!
    Sep 2007
    2,783
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    992
    I found that one last night! Thanks Tyler.
    May 2009
    AB
    483
    Here?s a few pics from my Twincraft conversion I did awhile back, it?s a 2230 on 10s. I used carbon fibre for the tube and end cap.
    Namba District 16
    992
    Do you prefer the flood tube to a stinger?
    May 2009
    AB
    483
    I primarily run hydro?s so I?m more used to struts and I wasn?t sure how much adjustment I would need on the boat. Plus it was something new to try
    Namba District 16
