I have been thinking about going electric on my 48" ML Boatworks mono but I'm not sure what motor to run.
I'm thinking either a Leopard or SSS in the 56mm dia. range but not sure which length. 105, 114,123mm etc.
I'm thinking an ESC in the 300 to 400A range should work.
I'm trying not to break the bank is why I'm thinking of either a Leo or SSS motor and maybe a Flier ESC. https://www.amazon.com/dp/B088WLTWL5...v_ov_lig_dp_it
or https://www.amazon.com/dp/B0832CZZYT...v_ov_lig_dp_it
From what I have read most are fairly happy with the Flier ESC.
I'm guessing for props I would start somewhere in the 65mm range?
I want to run it on 12s to be able to use the existing 6s 5000 packs I already have so I would guess the KV should be around 700 to 800kv?
Anyone using the Leo or SSS 56xxx motors on 12s?
What props, hulls, and ESC.s are you using.
The boat has a 30+ gas engine in it now so I would simply just get an electric mount for the 5" rails and fit it in the boat is my plan.
Any insight greatly appreciated.
I've been doing a ton of searching and really haven't found too much on these motor and esc setups in that size of hull.325727246_845466506533703_5084798763550206154_n s.jpg
Won't be for racing or any sort of competition just playing around but I hope to get at least 60 mph out of it.
Thanks guy's.
