Originally Posted by
Fluid
The motor Kv is really too high for 4S, it would work better on 3S. The prop is on the large side but might work if you kept a close eye on temps. This little boat will work best on calm water. Back in the day we raced 19? Key West cats with brushed motors and round cells, they were lots of fun!
Fluid is right at 3s is about a normal rpm range unless you’re looking to run a brushless turbine at almost 50000 rpm. You can run a 4s on a 425-430 prop, but at those speeds the drive train will not survive very long. The heat will toast everything.
Do you know what the biggest problem with the world is?
That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
