Results 1 to 7 of 7
Thread: Stinger or strut for 26 inch H&M mono?
    Mar 2009
    AZ
    992
    Default Stinger or strut for 26 inch H&M mono?
    I’m not sure if I need a strut or stinger for this boat.
    Jan 2020
    Az
    514
    Wow that thing is thin in the back, I would go stinger purely off of mounting space
    Mar 2009
    AZ
    992
    It’s an eco that can be run and built as a mono. I think its better suited for eco.
    Mar 2020
    NH
    325
    you run it as mono 1 ,you can find some idea's here on the forum
    Mar 2011
    BC
    7,629
    From looking at it and it’s given size I think I would just run the stuffing tube thru the transom. Set it to a height off the keel based on the diameter of prop you wanna run. Aim for the prop running 33% in the water on plane. You can put a bushing in the stuffing tube for the prop shaft to ride on..
    Shawn
    Mar 2011
    BC
    7,629
    You can check some Europe forum sites perhaps for comparison pics
    Mar 2020
    NH
    325
    look at how to tune a stepped mono for racing on the forum jesse j has the same hull and you find some mono 1 and2 in the uk
