Results 1 to 10 of 10
Thread: Collet. Do I need reverse or positive?
    Jan 2023
    67
    Default Coupler. Do I need reverse or positive?
    Hi everyone I hope this post finds you all well. I'm confused about coupler direction. I see that some are described as positive and reverse. If my prop spins left (ccw) as viewed from the transom which coupler is needed? Positive or reversed? Thank you.
    Chris
    Oct 2009
    FR
    2,096
    Use the same collet model for both sides.
    Mar 2009
    AZ
    992
    You’ll want your collet to tighten in the opposite direction that your shaft spins. Reverse collets are for twin setups when running counter rotating props.
    Jan 2023
    67
    Awesome thanks a lot.
    ON
    2,913
    Quote Originally Posted by Alfa Spirit View Post
    I see from your comment that you have never ran a twin boat with any power.
    Larry
    Oct 2009
    FR
    2,096
    Larry
    You’re a funny you ... The nut does not touch the flexshaft.
    Jan 2023
    67
    Just to clarify, are you saying that either coupler be it positive or reversed can work on a left hand (ccw) rotating prop?
    May 2021
    TX
    42
    I hope so cause if not it's Loctite time for my Miss Geico LOL.
    ON
    2,913
    On lower power twin boats - using two right hand collets is OK.
    I have never had any problems on boats up to 4S or even 6S.
    On my 8S twin I had to use a reveres collet on the right hand Prop side.
    When I put a right hand collet on that side.
    The motor had so much torque that the inner part would start to spin,
    The weight of the NUT would want to stay stationary, therefore coming loose.
    This set up is 8S - 400A - over 10,000 W per motor.
    The problem on my 6S boat (7,000 W) was that I had to tighten the collet
    on the side of the right prop so tight that I started to strip the threads on the collet,
    So I changed to a reverse collet on this boat also.
    Larry J.
    ON
    2,913
    It does not have to touch it.
    It is called Inertia.
    Larry
