Results 1 to 7 of 7
Thread: Coupler size help
    Jan 2023
    67
    Default Coupler size help
    I'm new to boating needles to say. I'm having a marvelous time understanding coupler sizes. I need a coupler for the following setup.
    Motor shaft: 5mm
    Flex shaft: 4mm
    So I'll need a coupler that's 5mm to 4mm flex shaft is this correct? Is that sold here? Can someone point me out?
    Thanks and happy 2023
    Mar 2020
    NH
    326
    OSE sells them and every thing you need
    Sep 2020
    Tx
    286
    Aug 2022
    PA
    52
    Open the sales items page here at OSE.
    Product ID ose-81513
    In Stock 20
    OSE 5mm to 4mm Collet steel coupler
    Jan 2023
    67
    Awesome thanks. So just for learning purposes what is positive rotation and negative rotation when purchasing a coupler?
    I know it's the direction the drive system rotates. But which is which? Positive = clockwise?
    Sorry for the noob questions.
    Jan 2023
    67
    That clears it up for me thank you.
    Oct 2015
    174
    Never heard of the right hand rule. I guess it works. Sounds quite confusing. Look at the boat from the back. Looking at the transom. Standard rotation is ccw. If you are running twins then you need a reverse wound flex cable and a prop usually designated with a R at the end of its size. Both are appropriate cw rotation. Actually quite simple.
