Results 1 to 12 of 12
Thread: Delta Force 41 single setup build
    Jun 2016
    Os
    70
    Default Delta Force 41 single setup build
    Purchased a DF 41 mono - two layers carbon
    Single motor. Will build this for a SAW mono. Goal 100 mph
    Edit 31.12.2022: The drilling of the holes or assambling the hardware wasn't done by me. I partly glued the hardware inside the hull, selected and soldered the electronics to make this a high rpm setup.
    Jun 2016
    Os
    70
    Motor mount custom ordered with 8mm thick carbon.
    Front and rear mount will fit both 56 can and 60 (LMT).
    Jun 2016
    Os
    70
    May 2009
    UK
    1,018
    which motor? i got close with a 1000kv 3060 on 10s
    Uk SAW record holder
    May 2009
    UK
    1,018
    - i posted that before reloading and seeing your post
    Jun 2016
    Os
    70
    Quote Originally Posted by vvviivvv View Post
    😂 No worries.
    Wow, thats interesting. Will I find any post or videolink searching this forum?
    May 2009
    UK
    1,018
    I didn't really document that boat too much, it was a Hydro marine no step 4, it ran consistently 90mph on a prather S235 prop.
    setup was SLS QN 65C 10s, schulze 40.161 and the 3060, it would still be cool after a full 2-3 min run i started experimenting with more props but didn't have too many that were appropriately sized and started having a few heavy crashes so decided to slow down and focus on going fast with other boats.
    May 2009
    UK
    1,018
    Here is a video from the shoreline of it running before i started pushing the limits and having crashes
    thats me out in my zodiac
    https://youtube.com/shorts/ZgTwKg4KWXI?feature=share
    Jun 2016
    Os
    70
    Very nice. Thanks for sharing :)
    Jul 2010
    UT
    152
    Nice project Amisol, with an impressive setup. I've seen your achievements on YouTube and you sure know how to build fast boats
    Jun 2016
    Os
    70
    Quote Originally Posted by Dirk Jan View Post
    Thanks, Dirk
    Jun 2016
    Os
    70
Tags for this Thread
