Results 1 to 5 of 5
Thread: I have 2 plugs coming off of ESC and running 2 batteries. I want to run 1 6s battery,
    Sep 2022
    ky
    17
    Default I have 2 plugs coming off of ESC and running 2 batteries. I want to run 1 6s battery,
    I have 2 leads coming off of ESC and running 2 batteries. I want to run one 6s battery, is the plug to transfer the power thru the unused plug
    called a Bind Plug Loop Connector ?
    Aug 2021
    326
    Yes,
    very common nowadays on RC cars.
    Example:
    https://www.horizonhobby.com/product...PMXSE1150.html
    Sep 2020
    Tx
    286
    If the two existing plugs are wired in series, which is likely and stock for a Sonicwake, then you need a simple connector that loops back on itself to plug into the unused plug.
    If the two existing plugs are wired in parallel, then you don't need to do anything but maybe cap the unused plug for safety purposes.
    2,918
    Pictures please.
    Will help a lot, are you asking about the radio plugs on the ESC, or the power plugs?
    Sep 2022
    ky
    17
    So must be wired in series, I found a loop plug on the bay and all worked well.IMG_0506.jpg
