Results 1 to 6 of 6
Thread: break away bolt
    Sep 2022
    ky
    17
    Default break away bolt
    newbie here, broke my break away bolt on a sonic wake v2, do I put 1 or 2 nuts on the bolt ?
    Aug 2022
    PA
    52
    I've only ever used one nut; just snug. Not overly tight.
    4,119
    Assuming it's a nylon shear bolt, a single nut is fine. If its a brass bolt, make sure it's a locknut. The nut just keeps the bolt from falling out, it doesn't provide a clamping force on the rudder blade. That's the pivot nut/bolt's job.
    Sep 2022
    ky
    17
    yes I'm using nylon, thanks for the replies
    Aug 2016
    Oh
    59
    Find solder that fits the hole size, bend both sides to keep it in place. Cheap and easy to put on.
    May 2021
    42
    I here some just use a zip tie and they come in different color's.
