Results 1 to 7 of 7
Thread: Receiver Battery, Confused as hell
    Dec 2007
    me
    406
    Default Receiver Battery, Confused as hell
    I am running a hydra 240 and a neu 2215 with a futaba 3pm radio, do i need a reciever pack? if so what type or can i add a bec?
    Not sure what to do
    Thanks Guys
    Nov 2007
    1,397
    Big motors and high voltage usually run separate receiver packs.
    Disconnect the red wire from the ESC to the RX. Then use a 5-cell NiMH pack with its own switch between the pack and RX.
    I use this set up on every boat except my SV27 powered boats. There I use the built in BEC on the ESC.
    Don't get me started
    Dec 2007
    me
    406
    will i need any special connectors or charging leads?
    Mar 2008
    So
    1,006
    Just a lead to plug the Rx battery in. My charger had on in the package deal.
    Oct 2007
    273
    is it a HV 240 or a hydra 240
    Dec 2007
    me
    406
    hydra 240 not the HV one
    Apr 2008
    Albuquerque
    81
