Hi all i am running a ML boats 34 inch Wild thing mono on 6s with a TP 4050 1330 kv 5y motor 6 mm bullet plugs swinging a x646 prop with the Swordfish pro 220A-6s esc .While running the boat on the weekend about a minute in to the run the boat stopped upon checking both esc and motor where about 75 degrees barely warn and no burning smell of any kind . I plugged in another esc and the motor worked fine . I am guessing this set up should not draw more than 200 amps . Are the 6mm bullet plugs to small ? Flex shaft turns freely . What suggestions for a replacement esc ? Regards Andris Golts.
