Results 1 to 17 of 17
Thread: 50" Mono Twin setup, I need help.
    FR
    2,096
    Default 50" Mono Twin setup, I need help.
    I' ve got a mono hull, 126cm or 50" if you prefer. This mono will run with a twin setup.
    The problem is choosing the correct voltage for this hull, 2 x 6s, 2 x 10S ? What must be the max RPM unload, 30.000 or 35.000 ?
    Here is the hull :
    Mar 2020
    NH
    326
    that's a very nice hull, with a twin set up you get a very heavy hull (only the drive line is about 4.5 to 5.5 kg) but 10s and 900kv should be good and ztw 300 esc's
    FR
    2,096
    @ koen, do yo mean 2 x 10S ?
    Mar 2020
    NH
    326
    yeah because you need big motors ,to keep amps down and volts up
    FR
    2,096
    Does a 2 x 8S setup sound good for a 50" - 126cm mono ?
    Motors : TPPower 4060 (40 x 94).
    Mar 2020
    NH
    326
    8s will work in combo with 4070 or 5660 works best(in my opinion )
    FR
    2,096
    Quote Originally Posted by koen View Post
    Do you know the weight of 2 x 56XX motors ? 1680 Grammes .....
    I wish I had other opinions, that would be cool.
    Mar 2020
    NH
    326
    2x5660 is 1800 but a pair of 4070 1400kv is 1300 ,SSS 4092 1400kv 1150 or you can opt for one motor also less hassle and price
    FR
    2,096
    Sep 2012
    Tg
    1,439
    You could go with a 56 x 115/125 motor 500kv, 300A esc on 10s2P. That would allow for bigger props, even 1/4" and give good speed. You haven't said what are your goals?
    May 2009
    UK
    1,018
    I run a 1.67m heavy mono on 2x 700kv lehner 3040 and 12s, does circa 70-80mph depending on props..
    Uk SAW record holder
    FR
    2,096
    Quote Originally Posted by vvviivvv View Post
    My mono is 1,26 m. , not the same range.
    2,730
    Quote Originally Posted by Alfa Spirit
    If you want something in between a long 40mm and a short 56mm motor you might want to look at the 44mm Lehner 22xx series motors.
    Sep 2012
    Tg
    1,439
    You still have not told us what are your goals? Speedfreak, cruiser, racer?
    FR
    2,096
    I want a good speed for fun.
    What do you think abour 2 x 8S , 4092 motors 1100 kV ?
    Sep 2007
    2,783
    You need to start with the limiting component in the power system: The ESC. If you have access to a good HV ESC like a Schulze or MGM then there are good options to go 12S. If you have a lower voltage ESC, then use the max input voltage the ESC can handle. Have you selected ESC's already?
    If no, and you want 8S I would highly recommend looking at the Castle Hydra XLX2 which just got released. This is an 8S 400A capable ESC with logging.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    FR
    2,096
    I have a set of ZTW Seal 150 A. High Voltage
