Results 1 to 18 of 18
Thread: Twin 6S Avenger Cat Update
    2,910
    Default Twin 6S Avenger Cat Update
    I have made some changes to my 6S Avenger Twin Cat
    I now have installed a Pair of Castle X8's
    TP 4060 -1650 KV and ABC 1816 Props
    Two runs on Sept. 11-22 they both came back at 80 MPH.
    https://www.facebook.com/561390943/v...67549743410494
    After this run I put a longer rudder on it, much better now.
    2,910
    X8's
    Sep 2020
    Tx
    286
    Looking good!
    2,910
    Quote Originally Posted by tbonemcniel View Post
    Looking good!
    Thank You Andrew
    Jun 2020
    MA
    90
    Going to be building a twin Avenger over the off season. What are your measurements for your motor mounts
    2,910
    Quote Originally Posted by Jonathan DeMaria View Post
    Jonathan
    They are easy to figure out and make. Use a piece of thin cardboard and start trimming, trim and fit, trim and fit.
    I don't have any prints of them any more, To get a print of them now I would have to do the above.
    Sorry Larry
    FR
    2,095
    Nice, what the size of the Avenger cat?
    2,910
    Quote Originally Posted by Alfa Spirit View Post
    Alain
    The hull is 36" long X 14 1/2" wide
    FR
    2,095
    36'' is not a long catamaran, is the hull heavy ?
    2,910
    Our rules for "Q" class is 40" Max. and 6S .
    This boat is for Oval and Offshore racing, not zip-zip in a straight line.
    I never weighed the bare hull.
    2,910
    Here are some pictures of the repaint that I had done this Spring.
    Jan 2020
    Az
    514
    Looks great
    Mar 2023
    tn
    538
    what props are those? ABC? I building a sprint cat 42 so your data logs are pretty interesting. Hard to read though with all the parameters at once.
    2,910
    If you are building a 42" You should read up on my 41" 8s cat.
    https://forums.offshoreelectrics.com...ld-8S-Twin-Cat
    Mar 2023
    tn
    538
    in the other thread you posted 2 logs is that for each esc? You're running twin 5670 TP motors @ 4000w average?
    2,910
    YES one log for the Right side and one log for the Left side.
    Mar 2023
    tn
    538
    im running a 4070 single and got to 55mph but pulling 4000w doing it. everyone has told me something is wrong. Ive spent all week trying to eek out any kind of efficiency from this hull. But if its taking 8000w on yours to get 86mph that kinda tells me it takes a ton of power in these larger catamarans.
    2,910
    55mph for a 4070 single, in a 42" cat, is not bad.
    In my 41" cat I am running two 5670 1170KV with two XLX2's and 2115 ABC props.
    This page is my 36" cat Twin. you want my 41" Twin (look below)
    Look at the thread here;
