Results 1 to 12 of 12
Thread: TP-Power TP3640-2600KV-Open-5F Motortiming seaking 180AMP
    Sep 2022
    br
    4
    Default TP-Power TP3640-2600KV-Open-5F Motortiming seaking 180AMP
    Hi All!
    i have a question, does anybody know what the correct timing setting is for a TP3640-2600KV- with a 5F winding in combination with a Seaking 180amp.
    thanx in advance!
    best regards
    Dennis
    Aug 2018
    Ky
    176
    good place to start....15 degrees. It should be a "Y" wind.
    Sep 2020
    Tx
    286
    Quote Originally Posted by Mrdennis1979 View Post
    Hi All!
    thanx in advance!
    best regards
    Dennis
    What is this 5F winding you speak of? Windings can only be Delta (D) or Wye (Y).
    A TP 3640 2600kv is a 3Y winding, which means it will generally prefer higher timing. However, 15* might be too much. I typically set my Y wound motors at around 8* to start, make a run logging temperature and speed, then incrementally increase timing until temperature begins to rise to the point where it's not worth whatever extra mph (if any) it brings. At that point, back off to the previous setting.
    Sep 2022
    br
    4
    Quote Originally Posted by tbonemcniel View Post
    Ok thanx! great explanation thanx!
    The webshop of tp where i buy it here in europe says that it is a 5F
    https://tppower.de/epages/bd5f179c-6...3640_2600KVo5f
    But i will give it a try with the settings and make some measurements of the temperature
    thanx!
    Mar 2020
    NH
    326
    TP advice for d and y motors is a 0" timing
    Sep 2022
    br
    4
    Quote Originally Posted by koen View Post
    Thanx! will try it out!
    Aug 2018
    Ky
    176
    That may be what they advise...their way of being safe. You might get more run time and cooler temperatures. But to get the most power out of the motor without burning the house down...starting at somewhere between 10 and 15 degrees with a "Y" wind and the correct prop you'll have more fun. Just saying..............
    Sep 2022
    br
    4
    Quote Originally Posted by EddieM41 View Post
    Thanx Ed, will start low, and look at the temps, i'm running dasboata props for my IMPULSE 32 & ZONDA R, the zonda will also get an upgrade 2 TP3650-2350kv
    Mar 2020
    NH
    326
    these motors can pull a lot of amps(look at tppower.de you can see full spec of these motors ,max amp 264)if you go for a lower kv you can pull bigger props and stil stay cool and lower amps ,these motors are for saw not for racing
    Feb 2019
    385
    It says 3Y. Think the 5 = 5mm shaft. Scroll down the page a little bit to the specs. First spec is Winds , 3Y
    Sep 2020
    Tx
    286
    What are you talking about? Of my like 15 boats I think it is currently, all but 3 have TP motors in them. They all oval race perfectly.
    4,131
    The only thing I agree with in this post if larger props on lower kV. The rest is flat out wrong.
